Stainless Steel welded together with 7018 rod
  • Stainless Steel welded together with 7018 rod
    Do any of you know if Stainless should be welded with Carbon steel fill rod? I've always been taught to only weld Stainless to Carbon Steel. Any takers?
    Stainless Steel TIG Welder
    The only reason I can think of is, that if you ever need to separate them again, you can use a cutting torch to cut through the steel, which will wash the stainless as well. That was a trick I learned in the Army...if all you had was a cutting torch to cut stainless...you first run a steel bead and then you can cut through both the steel and the stainless and the stainless will wash away with it.
      That rocky is good,thingy
        Hey Rocky, Did you invent "ROCKY ROAD" Ice cream?
        Dynasty 350
        Hobart Beta Mig 200
        Twenty seven Hammers
        Three Crow Bars
        One English Springer Dog
        A Big Rock
          Don't even like it.
            I guess its true that you should never weld up Stainless with Steel Fill rod.
              That Rocky is as sharp as a marble.....lol just kidding I'll have to remember that trick, Nice.
