keg fueltank need help
  • keg fueltank need help
    im making a fueltank out of a keg if i weld mild steel to stainless with a flux core mig will it hold can't find a stainless coupler what can i do
    You'd be better off silver soldering or brazing mild to SS. I would look a little harder and find the proper SS fitting then use GMAW to weld it on.
      i can braz it will it hold thanks
        Brazing is very strong. If you have the torch, brazing the fitting on will suffice.
        Hank
        ...from the Gadget Garage
        MM 210 w/3035, BWE
        HH 210 w/DP 3035
        TA185TSW
          I brazed a 1" round emissions hole shut in a new gastank with a patch one time and it never leaked.
            thanks for all the help
              http://www.mcmaster.com would have a coupler from SS that you can adapt a hose barb to...Bob
              Metal Master Fab
              Salem, Ohio
              http://www.ceilingtrains.com/
                As would pretty much any plumbing supply. Even home depot has a selection of smaller 304 fittings around here.
                  You could contact a machine shop in your town and i am sure they could make you any type of stainless steel fitting you need you just need to talk to then i am sure it would not cost too much
                  Hobart Tigwave 250
                  Hobart Pulser
                  Hobart Tig Cooler
                  9X42 Bridgeport
                  14X40 Engine Lathe
                  Darex Tool Grinders
                  Hor.&Ver. Bandsaws
                  Boyar Schultz 6X12 Surface Grinder
                  Never Forget Our Freedom is not free! Thank you to all of the serviceman and woman in harms way overseas because without them we would have no freedom! God Bless The USA!
