pipe welding
  • pipe welding
    how do you weld magnetic pipe together
    If you are having problems with arc-blow, just switch to AC stick (or borrow an ac machine). You can also try to demag the pipe, but it's usually not worth the trouble.
      Welcome to the forum.
      Lincoln A/C 225
      Everlast PA 200
        There are basically two ways,
        Remove the magnetism altogether by heating material to the Curie Point, typically 1000C and allowed to cool in a zero field or reverse the local magnetism using externally applied fields.
        The alternative approach is to reverse the magnetizing field dynamically as the weld progresses.
