Welding 4140 to A-36
  • Welding 4140 to A-36
    First, off, I am a blacksmith who is making an anvil from three pieces of plate. I am using a 1/2" spacer between them. I have a lincoln 225AC welder. I have to weld 4140-A-36 and then A-36 to A-36 with a 1/2
    spacer as well. I am wondering what kind of rod(s) I should use for this?
    Thanks and Best Regards
    Preheat both parts to 400F
    weld with 7018 rod
      I never responded to this, not being convinced how good an Idea this is.
      Since you now have sound advice, and may have allready made it;
      You may like to know that 4140 is the perfect alloy for haveing your anvil face
      "flamehardened".
      Alass I have no idea how to do it properly.
      The grand-wizard of flame-hardening did a huge deep-draw punch
      and die, (draw-forming) and was done before I got to work on second shift.
      vg
      sigpicViceGrip
        good luck to you and do show the pic then too and 7018 is gud tool suggested by Mike.... thanks and see ya
        mcse 2003 , mcitp certification , mcts certification , mcse 2008
          Tack pcs together and then pre-heat to 400. Then weld with 7018. This has never failed me.
            I adore the Lincoln Tombstone. Rock solid simplicity and everlasting.
            I heard somewhere that Lincoln was discontinuing the 225AC. What a shame if true.
            That has to be the best entry level welder ever produced.
              4140 to A-36
              I posted a video on Youtube a while back illustrating the Navy clip test for welding soundness of fillet welds using A36 as the vertical menber and 4140 as the bottom plate. Click on the link below>
              http://www.youtube.com/user/alpho52?...10/OSki3QuOJcE
              Century 250 AC/DC, MidStates 300 AC stick welders, Century WF flux core welder Harris weld/cut outfit Saws, Mill, Lathe, grinders ect.!
              SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
                I'm not the expert on this, but one of the guys in my guild is. He has made repairs to cracked anvils that were invisible when he was done and that was it; preheat to about 400 (he used Tempil (sp) sticks to determine the temp) and then used 7018.
                Blacksmith
                Stickmate LX AC/DC
                Big cheap (Chinese) Anvil
                Hand cranked coal forge
                Freon bottle propane forge
                HH 210 and bottle of C25
