Magnesium case
  • Magnesium case
    I welded a customers Mag case (motorcycle) today and had a real tough time keeping it from creating porosity spots........I kept the heat on low until it smoothed out but still had a hard time...I have welded mag before (Not too many times) and can't remember it being that bad...it was probably a dirty casting...anyone weld mag a lot with some tips next time for the dirty castings.....
    BC
    Dynasty 350
    Hobart Beta Mig 200
    Twenty seven Hammers
    Three Crow Bars
    One English Springer Dog
    A Big Rock
    BC
    Ive had to do some nasty cases as well. What I found that seemed to help was using a puler seting of about 120Hz with an AC frequency of around 175-200. This creates a rapid freeze-thaw in the puddle that helps bring the grunge to the surface. I also have been thourghly cleaning and baking the castings beforehand to help migrate the oils to the surface.
    -Aaron
    "Better Metalworking Through Research"
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Smith, Meco, Harris, Victor, Prest-o-lite, Marquette and even a Dillon O/A torch
      The only OVEN I have is Momma's and she will hurt me if I put a part in it...How about pre-heat with OA?
      You must have an inverter welder with those specs....I have a Lincoln tig 355 sq. wave...What pps and background current would you suggest? I figure from experience with the pulser I would maybe use 3PPS and 50% background and maybe 150 amps and just work the pedal to make things happy......What do you think?
      B_C
      Senior Member
      Dynasty 350
      Hobart Beta Mig 200
      Three Crow Bars
      A Big Rock
        Never really checked before....Are there different grades of Mag Filler?
        Dynasty 350
        Hobart Beta Mig 200
        Three Crow Bars
        A Big Rock
          Yes,AZ61A and AZ92A.
          http://amfiller.com/files/mag_chart.pdf
          This is pretty cool.
          vwguy3
          Senior Member
            So is there a good way to tell which one you need?
            I have some I bought like 10-11 years ago or even more and could not tell you what it was if my life depended on it. It has always worked for me tho
            It was $75 a pound back then.
            Miller Dynasty 700...oh yea baby!
            MM 350P PULSE SPRAYIN' MONSTER
            Miller Bobcat 225 NT
            Miller Dynasty 200 DX
            Miller WC-115-A
            Miller 30-A spoolgun
            Airco 300 Heliwelder (465 amp and made by Miller)
            Miller Spectrum 300
            Lincoln SP-135-Plus (down the road now)
