Square Tube Set-up and Weld
  • Square Tube Set-up and Weld
    I'm welding thicker square tubing for the first time and would like so advice and comments.
    I am doing some practice welds on 3 x 3 x 1/4". I have put a bevel in which leaves about half the material thickness.I'm leaving a gap of about 1/16" between the pieces. I am doing it in two passes , the first a straight pass and the second one a stitch.
    Settings are 4/60 on the 180 machine with .035" wire.
    Hobart 180 Handler
    Looks good to me. However, I'm curious as to why the gap? In our shop we weld tons of this material weekly and do not gap.
      In theory with thicker materials, the "gap" allows better penetration....
        Yes I understand, but unless its requested on the shop drawings by the engineer we don't do it. Some engineers are more fussy than others for sure, but only under extreme structural stress do they [rarely] request it.
          Is it the 1/16" gap you are referring to? Just something I read, I have no experience with this material and am just a rookie welder looking for tips and feedback.
          Is the spatter being produced more than normal and the bevel OK?
          Hobart 180 Handler
            Here's and article you may find informative
            http://www.lincolnelectric.com/en-us...netration.aspx
              At the home/hobby level a small gap leaves a whole lot more adjustability for square, especially after the 1st and/or 2nd tacs. It also helps insure better penetration. Nothing wrong with better than the minimum required. Nothing wrong with extra effort. We're not all in a production environment.
                My instructor would've told me to 'wrap the corners'! Looks good to me otherwise. The other thing with the gap is I think some guys want to see the edges melt so you know you're getting CJP----otherwise you're just assuming! (that's my theory on that anyway)
                  [ATTACH]37100[/ATTACH]
                  [ATTACH]37101[/ATTACH]
                  [ATTACH]37102[/ATTACH]
                  [ATTACH]37103[/ATTACH]
                  [ATTACH]37104[/ATTACH]
                  Fit up looks good. Spatter looks a little excessive, are you using C25 or straight CO2 ?
