need help welding 16g metal..
  • need help welding 16g metal..
    using a hobart 220 mig i have the setting on 1 and wire speed wayyy down using flux core and i cannot get a bead no longer than 1/2" without burning through and im trying to be quick..
    any tips?
    Is your machine set on DCEN.? What type of joint Butt,lap,etc. Try increasing your wire speed. Or try 2/25 may have to decrease wire speed to 20 if you are using 0.35 wire. Get a taste of it you may have to run fast on your travel speed. Can you use a backer strip.? Clean all your joints. Try it on some scraps and tailor your wire and travel speed, so you don't mess up your job.
    sigpic
      im using .030 wire ill try making sure everything's as clean as possible...
      im doing inner and outer edge fillet welds if that makes sense...
        Originally posted by lakailimited06 View Post
        any tips?
        .030 bare steel mig wire and gas. Welded it everyday for years...Bob
        Metal Master Fab
        Salem, Ohio
        http://www.ceilingtrains.com/
