how to keep unpainted steel from rusting
  • how to keep unpainted steel from rusting
    im looking for ways to store a set of cam shaft and a couple crank shaft so they will not rust.the only idea i have is to whip like axle grease or other thich grease all over then and put them in a box lined with bags to hold in the thich grease is there any other idea how to store parts like cam shaft and crankshaft or what not. i understand they are harden steel but they would be the same as store mild steel right? also parts like that cant be painted so dont even say that
    have
    hobart handler 187
    lots of hand and air tools
    motor lift,motor stand
    2 tall tool boxes
    lots of shop lights
    2 wood stoves "still not enough heat for my 6 car shop"
    6" ginder
    hand ginders
    2 work tables
    14" chopsaw
    drills
    3 floor jacks from 3000 pounds to 33,000 pounds and countless jack stands
    need
    more clamps
    more cutting tools like torches
    LPS-3 is one thing you might try: http://www.lpslabs.com/product_pg/co...n_pg/LPS3.html
    Another is Fluid Film, available from John Deere dealers as I understand. http://www.fluid-film.com/
      Boeshield is another good choice for rust prevention.
      Mig - Hobart 187
      Plasma - Miller 375
        Unless you are storing them in the rain, I would think that even a coating of motor oil would fend off moisture for quite a while. Gear lube is pretty sticky but would still be easier to clean off than axle grease. It's also easy to find, though a JD dealer can't be too far away either.
        That Boeshield looks a little pricey!
        Dave
        Square Wave TIG 200 - Woot!
        MM180
        SP125+
          I didn't make those recommendations lightly.
            I would recomend using Cosmoline.
              simple motor oil/gear oil would be fine, if you are bagging the parts and storing them in a semi-controlled enviroment. For longer term, coat the critical areas with something like wheel bearing grease before bagging.
                we used to store parts in alcohol, or paint thinner. Just let them sit submerged in a sealed jar.
                In case of welding emergency
                use a bolt
                  a crank and a cam would require a pretty big jar.
                  Dave
                  MM180
                  SP125+
                    I've used LPS-3 and really liked it and the spray application is handy. How does Fluid Film compare?
                      I haven't used Fluid Film but it looks very promising from what I've seen. It's lanolin-based. Ever see a rusty sheep?
                        Yep.
                        Hobart HH 125EZ
                          Zrexxer
                          Zrexxer....your a smart a$$!
                          I like ya already!
                          Ol' Dakk'
                          Me: Hey Longhorn, hand me that piece o' metal ?
                          Longhorn BSCE : Sure John, here ya....ARRRGGGHHHH!!!
                          Me: It might be a tad warm there 'Horny...
                          Too much gear to list and none of it any different than any other single-hand welder.
                            Z,
                            Been over to Hotfoots?
                            Hank
                            ...from the Gadget Garage
                            MM 210 w/3035, BWE
                            HH 210 w/DP 3035
                            TA185TSW
                              Dakk, like I always say - better than a dumb a$$
                              Hobart HH 125EZ
