angle vs rec tube
  • angle vs rec tube
    I'm planing on making a tandem axle trailer. I have a question concerning frame material. The ones sold around here are made from angle usually 2x3x3/16" some use 1/4" and I've seen some using 3x4x1/4". With the side rails I'm sure it acts like a truss making the frame stronger.(see pic) My trailer plan is 5' wide by 16' -18' long(not sure yet) It will have 2 3500# axles for a 7000# GVWR. I don't plan on hauling anything more than 2 atvs and a Rhino, approx 2500 pounds. I think at 16' length the 2x3 3/16 would probably work. At 18' length I would feel more comfortable with the 3x4 1/4". When I went to price out the steel, the 3x4 was $5 a foot. I was thinking of using 2x4x 1/8 tube for the tongue. It is $3 a foot. This got me thinking. Couldn't I use the 2x4 tube for the frame too? Which would be stronger? Both would have the side rails. I think the angle would be easier to work with. Is it not even worth considering just to save $72?
    self taught amature, SIP 115V flux welder (retired) Now using a Clarke EN180 220V machine
    From my armature/hobbyist point of view, I think I would use the angle.
    1. The tubing has twice the area to harbor rust. (inside the tube)
    2. The 180 that I have sitting on the shelf now, runs a very harsh hard to control arc on the high setting. I never used mine on anything critical. Someone else will have to chime in on if your machine will be acceptable. Maybe with proper bevel/prep and the ability to weld both sides of the angle.
    I am not saying you should or shouldn't, but rather the way I may attack the project.
    Good Luck, and please post pics along the way.
    Tom
    Stickmate LX 235 AC / 160 DC.
    MM211 AS and Spool-Mate 100.
    Spectrum 375 X-Treme.
    O/A Medium Radnor Torch, Large Victor Torch.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Rockworth 80 Gallon 2 Stage 16 SCFM @ 175 PSI , 15 SCFM @ 90 PSI.
    Jackson Passive Shade #5 for the plasma.
    I almost forgot the Hobart XVP AD Hood.
    Speedglas 9100x
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
      Here are some pros and cons of each...
      Tubing does have to be sealed up or left relatively open to allow it to either keep moisture out, or to let the moisture escape. Angle does not have the interior to worry about.
      Tubing is torsionally stiffer, so the trailer will tend to twist less than a trailer made of angle. A good compromise, and not much more costly than angle (by weight), if at all, is to use structural channel. Have a look at some of the other commercially made equipment trailers and car haulers. Many are made using channel.
      For the same section height, vertical deflection will depend on the lateral thickness of the material used. In other words, if you use 3x4x1/4 angle, with the 4" leg up, it will resist sagging about the same as a 2x4x1/8 tube stood up will, provided you can keep it from twisting.
      For a long light trailer, thinner taller material can be used to keep it light, but it will be more susceptible to damage.
      If you are only going to be using it for the quads and the Rhino, you could also use lighter angle and build it like most utility trailers are built. This gives you a tall side, with plenty of places to tie down to. And it keeps things from sliding off the side.
      Be sure to take into consideration how the weight will be distributed when loaded. If you plan, for example to load the Rhino at the back, you will want the axles centered farther back than if you put it in the middle or at the front. Just remember that you want approximately 10% of the trailer's weight on the tongue.
      If you visit Big Tex's website, you can download datasheets for their trailers. You can see what materials they use and where the axles are located.
      You didn't mention what material you are going to use for the deck. If you want light weight, expanded metal is the way to go. It's also nice for quads if you plan on getting muddy, as the mud can fall through instead of accumulating and getting slick on top of wood or diamond plate. However, it adds almost nothing to the structural strength of the trailer, requiring the frame to be able to support itself safely on its own. If you use wood or solid metal for the deck, you can plan for it to provide some strength to the trailer.
      Just my 2.1¢.
      Dave
      Square Wave TIG 200 - Woot!
      MM180
      SP125+
        Angle stock, is not intended for serious cross-loading.
        It is to be used for ties, where it caries tensil loads only!
        It provides two faces for bolting to other members that
        are 90 degrees to each other.
        Use box tube !!
        Vg
        sigpicViceGrip
          Thanks for the advise. I havn't figured out the floor yet either. Expanded metal would be Ok but I'd have to add more support to stop it from bending. Wood and expanded metal are about the same cost(slightly more for the metal) when you figure in hardware. A 4x8 sheet of 3/4 #9 is $45. I can find 5x10 but I dunno about the cost. Here are pics of the first trailer I made. Here I used 2x3 tube for the frame because the sides are removable. The floor joists are on 12" centers. So far the expanded metal floor has not bent. http://home-and-garden.webshots.com/...55492796zLnBId
          The Clarke 180 works pretty well. Of course I have not used any other machines so I can't compare. I have practiced on some 3/16 and 1/4 stock and it seems to do well there too. I do feel however a biger machine would be better for this large of a project. Kinda like building an ark with a hand saw.
            Don't think of expanded metal, think of catwalk grating. 3 or 4 pounds per square foot, it's structural. Probably still less weight than wood.
            Angle iron vs. tube. Tubular structure, in itself, allows for far more flex, and possible cracks. Run a crossmember to one side, then one starting on the other side of the tube, two inches between them.
            Always a well-distributed load???? should be fine.
            Myself, I've always preferred real structural shapes; angles, channels, I-beams. Weld one side, weld directly on the other side, same location. You create continuity between the various structural members, rather than "spaces". Not gonna have a box tube, distorting, because of some concentrated load or the other.
            *** Disclaimer ***
              Myself, I've always preferred real structural shapes; angles, channels, I-beams. .
              Wrong.........
              choises from best to worst are;
              Box-tube rectangular ........wider section paralell to cross-load
              I-beam
              Box-tube square
              Channels......prone to twisting
              Angles......no good cross-load srenght at all.
              sigpicViceGrip
                are 90 degrees to each other.Use box tube !!Vg
                Another case of trying to apply engineering theory to a single component with no consideration of overall deign or real-world application. Look around you, there are hundreds of thousands, if not millions, of safe, sturdy, well designed trailers on the road ever day, from 4 feet to 20 feet or more, all constructed of angle and certainly carrying heavier loads than a couple of ATVs.
                Hobart HH 125EZ
                  Your grammer, spelling, and sentence structure, are sure a lott better
                  than mine! I'm so happy I've been able to inspire such a good essay.
                  I am now so convinced you are correct, I'm going to look at semi-trailers
                  and in my niehbor's basements, to see all the wonderfull places
                  that angle should be used to make this a better / safer world.
                  Cheers
                  VG
                  sigpicViceGrip
                    Oh my .... even better!
                    I'm on a roll now !!!!!
                    I'm flipping nervously (all be it) excitedly thru the yellow pages;
                    so I can find a lawyer to make me a legal draft, so I can send it
                    to the factories where the many machines I have designed and built
                    are buisy clicking and buzzing away, destined for certain failure;
                    because I used box-tubing for the main frames, instead of angles.
                    I hope I get these off in time to avert dissaster.
                    Pfweeeew!
                    vg
                    sigpicViceGrip
                      Man just find a trailer you like and take a few dimensions. Then the engineering part of materials has been established. Which means your welding ability and welding schedules are the only question. It sounds like you are working that out currently. In KY in order to get plates for a home made trailer you have to have in inspected.
                        I have been building trailers for over 30 years with the same 3x5 angle design on some models. Now the newer angle trailers are pretty light duty thats why they add the top rail to keep them from bending. The only one of mine i know of that bent was a guy ran a little dozer up on his borrowed car trailer and made a nice arch in it. Had he blocked the back while loading it prob would have been fine...Bob
                        http://s110.photobucket.com/albums/n...0have%20built/
                        Metal Master Fab
                        Salem, Ohio
                        http://www.ceilingtrains.com/
                          I would nix the 1/8 square tube for the tongue and use 2x4 x1/4 tube for the frame including the tongue for the following reasons. I weld at a dirt moving company. We made an 8 x 20 trailer with no sides for hauling various stuff. Everyone said it was good for 20 ton. I begged to differ and stated the trailer was only good for the least rated item. Like the two 6k axles made it a 12k trailer or 10k at best. The 4 tires rated at 2500lbs each made it an 8k trailer, the 10k 1k hitch was more than the tires so the tires set the weight load limit.
                          Same trailer was loaded with from back to front with 2 scraper tires and a 3406 motor. Driven down a rough road the tongue folded at the trailer front do to the bounching effect. So much for proper loading.
                          Replaced the tongue with 2x4x1/4 and asked if ya knew the trailer was bounching why didn't ya slow down? I was only going 55. I continually see dual axle trailers loaded with considerable excess tongue weight so much so the tow vehicle is shooting for the moon and hardly steerable and the rear trailer axle hardly carrying any weight.
                          In this respect consider what ya want to haul. 2 ATVs and a Rhino. One aft of axles , one over axles and one forward of the axles. Now through in 65mph and rough roads. Will your design handle the flex effect of 2k aft, 2k centered, and 2k forward of the axles with angle iron or 1/8 tube for its life time or will I see your trailer folded on the side of the highway?
                          Some nice trailers there AA.
                          Don't forget to plan the trailer weight into the GVWR.
                            Mr Meck has it right.
                            It seems you are building a 7,000 trailer in some areas and a 3,500# trailer in other areas.
                            Why don't you make it a single axle 3500# trailer. You only want to carry 2500#.
                            When this gets sold at your estate sale many decades from now, somebody will go "look Double Axles, it's a 7K trailer, I'll just cheat once and put 9K on it. What's it gonna hurt" They will be surprised at the outcome.
                            A quick way to check yourself is to get you steel weight calculator out and add up the weight of your trailer. Your weight should be pretty close to professional trailers that you can find all over the internet. If you are not, you should be asking why. You are either overbuilding or underbuilding.
                              Wrong.........
                              I-beam
                              Box-tube square
                              On a trailer, I disagree. Tubing, by itself, yes, is stiffer. The problem is, most people, when engineering with it, cut sizes and wall thicknesses down, to get the same stiffness, with less weight. And also, say you are welding structural members, on either side of another frame member. Do you not have a hollow space between them, if you are using tube? Also, it is far easier, to rip a member out, spring hanger out, weld, wall in the tubing and all, than it is, to do the same, with any structural shape, whatever the thickness, noting there's usually another piece stiffening it welded directly on the other side of the wall or flange.
                              Crawl around under any 28' flat, 48' or 53' flat, any lowboy, any tongue-pull or gooseneck equipment or backhoe trailer, you will rarely see any tube in the frame.
                              One thing you will also notice, crossmembers. Very important, the strongest trailers, that can take the most concentrated load, have the more closely-spaced crossmembers. This is what keeps angles, I's, and channels from bending and twisting under a load. They don't have to be heavy, they just have to be there, and the proper size and design to be stiff enough to do the job.
                              Even when I stretch truck frames, locating, placing, and properly installing crossmembers is almost as important, as how the splice is done.
                              *** Disclaimer ***
