galvanized sheet metal
  • galvanized sheet metal
    I have had some unused HVAC duct pieces for quite some time now. I'm just wondering if anyone knows any tricks to getting the galvanization off of the material in case this would ever come in handy. I'm simply not interested in welding (poison gases) or painting galvanized metal, but otherwise these are really nice pieces.
    I was thinking wire wheel but I have yet to try.
    HH187
    Hobart 500i plasma
    CLARK 4.5" GRINDER
    1/2 HORSE ROCKWELL/DELTA DRILL PRESS
    30 gallom 1.6 hp compressor
    DREMELL
    1998 JEEP CHEROKEE
    XBOX 360
    AGE AND WISDOM
    DESIRE TO BUILD STUFF ON THE CHEAP
    I had some galvy hurricane ties (before I even tried to buy metal, like 4 years ago) and I tried a wire wheel. It looked good but my DIY torch was hot enough to vaporize it (1" or so out from the brazed joint) and it made me feel sick. I think a wire wheel just removes the very top layer of nickel and makes it look less shiny. So does sandpaper. Maybe you could solder it?
    I think if the material is to thin to grind with 80 grit or so then maybe soldering would be adequate, and if it's thicker than that you don't have to worry about it being too thin.
    or maybe not
    Metallurgy
      well that doesn't sound very encouraging. seems like such a waste of nice sheet metal.
      HH187
      Hobart 500i plasma
      CLARK 4.5" GRINDER
      DREMELL
      1998 JEEP CHEROKEE
      XBOX 360
      AGE AND WISDOM
        If you aren't using mig or tig you can just put a big fan by it and do it outside. Then you can weld it. At your own risk. Get the consent of someone who has actually done it first though.
        Solder isn't that expensive either.
        Is there any reason you had to weld it? A something in mind? Just because you can't weld it doesn't mean you can't do anything with it.
        Metallurgy
          It is very thin, so any welding is going to require skill, or else you'll just blow holes through it (don't ask how I know that). Have you tried Muriatic Acid? I use it to remove the shiny coating on new bolts, chain, etc. Try a small piece, and see what you get...be careful...it is acid, so respect it!
          Yesterday, I posted this link to a Miller article re: welding sheet metal. Enjoy!
          http://www.millerwelds.com/resources...-metal-MIG-TIG
            Vinegar,(Acetic Acid) will remove galvanizing with out the rust vapor problems with some of the other acids. It is slower, but you don't have the disposal problems or issues either.
            Granted it does work better for bolts,nuts and it does take longer depending on the strength of the vinegar.
            And sheet metal large sizes my be a problem.
              flap disc or sanding disc on a right angle die grinder. Polish off around a quarter to half inch perimeter, and weld away.
              I don't think you need to worry too much with the galvanizing, unless you are welding a ton of it, I never seem to have seen this zinc poisoning thing, and I've welded a bit of galvanized here and there. The trick is to not stick your face in the smoke. My helmet seems to help with that. I do have a vent fan typically running in the shop while welding however, which probably helps.
                interesting sideshow because I recently learned of the many many uses of vinegar and how to strengthen it.
                It works great for cleaning concrete off of siding, cars, etc.
                any way, I just thought the steel could come in handy some day and it seems like a waste. maybe I'll use it for the blades of a yard windmill.
                HH187
                Hobart 500i plasma
                CLARK 4.5" GRINDER
                DREMELL
                1998 JEEP CHEROKEE
                XBOX 360
                AGE AND WISDOM
