Angle Iron-Which Way Is Stronger?
  • Angle Iron-Which Way Is Stronger?
    Hello: I want to use some scrap angle-iron to act as bracing members for wood running perpendicular on top, for a project, and wondered which would be stronger. Basically you can position angle-iron in different ways, just wondered which was stronger for lack of flexing. Attached Picture is looking at angle iron's position at the end. Any thoughts?
    Thanks in advance.
    I would think #1 in your picture, but I could definitely be wrong. just from handling it, seems that there would be more deflection under load in #2 or #3 orientation than in #1. I would do a test with a known weight and measure deflection in all positions on say, a 10 foot piece over a fixed gap.
    Hobart IM210
    Lincoln 225 stick
    Hitachi chop saw
    Big 'ol Walker-Turner drill press w/ XY table
    8" x 12" HF lathe
    '86 Toyota 4WD welding rig with 10kw homebuilt Genset
    '76 M880 for the heavy stuff
    --The quickest way to double your money is to fold it in
    half and put it back in your pocket.
      Still need a bit more information to answer the question. What direction will the wood be running with relation to the angle? Method of attachment to the angle?
        Take a 20' piece of angle and balance it, holding it in the middle. #1 will flex the ends down much less than the others, and be easier to attach at the same time.
          Very nice graphic illustration, by the way.
            Attached is another picture, showing the layout I was planning. Thanks.
              #1. MAC702 said all that is necessary.
                Bottom line...Mac is right...as per usual.
                  Yes and No
                  Mac's right per the question.
                  The question is based on a miss-applicaton.
                  Actually angle-iron is not meant to be load-bearing across it's section.
                  It is made to be used in "tension" situations, providing two surfaces
                  square to each other at the ends for attachment to the
                  (object requiring latteral reinforcing).
                  Channel is the preferred product you may want to considering,
                  based on structural applicication.
                  Yes angle is used this way in many applications including bed-frames, but
                  if you really desire / need good support, channel is a better choice.
                  sigpicViceGrip
                    Maybe it was originally called dangle iron?
                      I agree with Vicegrip.
                      Channel would be a much better choice in this application.
                      SundownIII
                      Syncrowave 250DX, Tigrunner
                      Dynasty 200 DX w/CM 3
                      MM 251 w/30 A SG
                      HH 187 Mig
                      Dialarc 250 w/HF 15-1
                      Hypertherm PM 1250 Plasma
                      Victor, Harris, and Smith O/A
                      Mil Mod 6370-21 Metal Cut Saw
                      Grizzly 6"x48" Belt Sander
                      Miller BWE and BWE Dig
                        Key reason that commercially built trailiers use channel!
                        Hank
                        ...from the Gadget Garage
                        MM 210 w/3035, BWE
                        HH 210 w/DP 3035
                        TA185TSW
                          If you have angle and want to make use of it, #1 is the best orientation. It will also be easier to attach stuff to. Channel or box could be better in this application BUT I think once the boards are tied into the angles it will stiffen them up just fine. Nice graphics, BTW!
                          TA185 TIG
                          MM210 w/Franken3535
                          AirForce 625
                          AirForce 250ci
                          Victor O/A (bored)
                          Lincoln Autodark (freebie)
                          Glock 30 w/ns for goblin disposal
                            way to use angle-iron for bearing lateral load
                            two opposed members, are required for load-carying applications.
                            Example , say a weld-table top.
                            cheers
                            vg
                            sigpicViceGrip
                              Thanks for all your input on this everyone. This website is extremely helpful from very knowledgeable folks!
                              I definitely agree that channel would be better, but I had a bunch of angle around so thought that would be better.
                              I went with option #1 and seems to be very stiff.
