I got a cheap gas meter,bottle of argon,and some cheap aluminum wire and try to make it all work. Well, I made sooty porous crappy booger welds all over the place. Would my gas meter not be flowing enough? I had it almost wide open. And my unit is a 187 handler. Are there some rollers with deeper grooves I can get to help it not bounce out of the gun on and off? It's sort of like you have the speed too fast and it bounces off the work but in reverse. The rollers are spinning on and off and maybe a new tip. Also in another post there was a guy talking about cleaning the o rings on his spool guns power pin? Whatever that is,I was thinking the o rings were letting air in and making the mess as he said his was doing. Or am I on crack? The wire is also .035 cheap princess auto. stuff. It might be the problem as well.
My mig and aluminum
Originally posted by gregorys201 View PostVery nice!I try to weld the aluminium but the result is not good,can you teach me how to do it right mate?
Then come back and we can discuss why your are not happy with your success or lack there of... Pictures help us analyze your problems with process....
IF you really want success go with TIG, but its a whole different learning curve and set of tools (welder)....
- 1 like
Al is fussy. About 25/30 gas and 3/4 stickoutvwith slight push. Also 030 works a lot better in the small machines.
