I bought a new Hobart 190 with Spool-Gun last month. . Last weekend I finally tried to weld aluminum.
I'm not used to the settings on the welder yet, I've only used it a few times on steel, and I know aluminum is harder to learn to weld. I learned to weld on a stick welder back in the 80's and used to be a welder underground in the coalmines. . So I'm new to MIG welding & welding with gas.
I can't find any videos of anyone using a Hobart 190 with the Spool-Gun 100, So hopefully someone here can give me some advice on welding aluminum. . I spent 3 days trying to learn the settings to weld aluminum.
Here's what I was using and the settings on the welder.
1.) The aluminum I was welding was a piece of 1/8" scrap I had.
2.) I was using .030 Hobart wire.
3.) Argon was set on 20 to 25.
4.) Welder voltage was set on 1.. ( as low as it would go)
5.) Wire speed was set on 70.
If I turned the voltage up higher than 1, It would burn through the aluminum. . With it set on 1, If I turned the "wire speed" down lower than 70, It wouldn't even start a bead. (it would just start to ball up)
Here's some pictures.
OK, As you can tell from the (first weld), It looked cold. . As I moved on down, The welds started to look hotter. . I welded all 8 passes without stopping, and the aluminum heated up.
Also, I didn't know but I was dragging the weld, and was told to push.
More pictures.
Where I have the ''red arrows". . Welder was turned down as low as it would go on 1, and wire speed was on 60.
Where I circled the welds in red, I turned it up to 5 and wire speed on 80. You can see how it started to burn through with the high settings. . I have also tried the volt settings between 1 and 5.
More pictures.
This time I used a different piece of aluminum. . It was a piece of 1/8" diamond plate. . I pushed the weld this time, and I was able to turn the welder up without burning through, But its still not the welds that I want.
1.) 1/8" piece of diamond plate
2.) Volt settings. 4
3.) Wire speed. 70
4.)Argon. 20 to 25
I practiced 3 days in a row, and just about used a roll of 1lb. wire!
Any advice would be appreciated!
More pictures.
More pictures.
3.) Wire speed. 70
4.)Argon. 20 to 25
