First time on aluminum.
  • First time on aluminum.
    Hey guy's i just thought i would comment on my first time welding aluminum with a mig. I have a HH210 MVP and spoolmate 100. I practiced on a piece not quite 1/8" thick. No photos but i was very impressed with how easy it was to set up and get started. It took me several tries to get it looking good but i think the set up works very well. I did burn back in the tip and stick the wire. Still haven't got it cleaned out so i guess i need a tip cleaner. One thing i did realize is i was able to weld better on 110v than 220v because i couldn't find the sweet spot on 220v. It is very thin to start on but other than the distortion on the backside of the plate i was pleased. Lots of tips on here so ill keep on reading just thought i would give a shout........Fireman Bill
    Fireman Bill
    HH 210 MVP
    MM 211
    Spoolmate 100
    Lotas LTP5000D Plasma
    Oxy/Accet (Victor)
    Wards AC/DC buzz box
    30 ton old hyd press
    A few brand name tools
    A bunch of cheap tools
    A wife to worry me and
    4 dogs to supervise me
    Extended nozzle available for some MIG guns and spool guns helps prevent burning back to tip.
      Yeah ill have to check them out. I will have to practice a lot more to get use to the different settings.
      Fireman Bill
      HH 210 MVP
      MM 211
      Spoolmate 100
      Oxy/Accet (Victor)
        Save some money.
        Well i have finally used my hh210 mvp w/the spool gun for something productive. My dad is fixing his 2000 Buick park avenue after hitting a dear. He was going to order the aluminum bracket that holds the headlight in. It was torn and broken in two places. We bent it back exactly like the other bracket and cleaned the areas that needed welded. Each place was about two inches long. I ran a bead from the middle out to each end. I am pretty impressed with the results so far. It saved $95 and was enjoyable doing. It's always nice not having to pay the big corps any more money than you have to............Fireman Bill
        Fireman Bill
        HH 210 MVP
        MM 211
        Spoolmate 100
        Oxy/Accet (Victor)
          Pictures would be nice!
          I just bought a Hobart 190 with a Spool-Gun, and finally tried welding aluminum last Saturday.
          Hobart Handler 190
          Hobart Spool-Gun 100
          Lincoln 225 AC
          Lincoln AD Helmet
          Dewalt 14" Chopsaw, Grinders
          Harris O/A
          Victor Torch
          Custom Built O/A Cart
          Custom Welding Cart
          HF Heavy Duty 16 Speed Floor Drill Press
          HF 12-Ton Pipe-Bender
          Drill Doctor!
            WB,
            How did you make out??? Do you have any pictures???? Welcome to the weld talk chatter box....
            sigpic
              Originally posted by urch55 View Post
              WB,
              Thanks for the welcome!
              Yes, I have some pictures.
              I turned the welder down on 1 as low as it would go, and could weld better than turning the welder up on a higher setting!. . I have a lot to learn, and hopefully I can find someone with a Hobart 190 that has welded aluminum.
              I'll start a new thread.
              Hobart Handler 190
              Lincoln 225 AC
              Lincoln AD Helmet
              Harris O/A
              Victor Torch
              Custom Welding Cart
              Drill Doctor!
                First time welding of aluminum should be very careful. As the aluminum gets heat earlier than other metal, so it can be dangerous for welding. Heat sink is preferred to absorb the heat of aluminum.
