tungsten melting away
  • tungsten melting away
    I am welding some cast aluminum parts and it takes a quite a bit of amperage . what is happening is that my tungsten gets too hot and melts back quickly
    I am using 100% argon
    Miller synchrowave 351, AC with high freq start
    Unfortunately, your post is noticeably devoid of any details that would allow anyone to help you... like what size and kind of tungsten you're using, and what amperage you're using.
    So you're running 100% Argon now? Because in your last post you said you were using C25 with that machine.
    Hobart HH 125EZ
      sorry, quite new to tig on aluminum, my first try actually
      I have an argon flow of 20 so that should be correct according to what I read.
      I am at about 125 amps in order to get the alum. to flow
      I can weld for a very short time and then I see the tungsten is very red
      size of tungsten is 3/32
        125 amps shouldn't make your tungsten melt. Maybe you got a piece of stainless rod by mistake. We used to sneak one in on a guy when he took a break, then waited for him to strike an arc with it...
        Welding 1/4" and above, I use 1/8" 2% thoriated tungsten. Pure is recommended for aluminum, but 2% works just fine, too
          Definately not enough useful info, but what the heck.
          Are you running pure tungsten on DC? This would 'melt' it quickly.
          You should run pure (green) on AC. Let's assume you are running pure on AC as you should.
          99% of the time, if you are melting your tungsten, go up to the next diameter.
          Scott
          American Made
          Haul your MX or offroad bike without straps -> www.mxtras.com
          MXtras' Storage Cabinet thread - http://www.hobartwelders.com/weldtal...ad.php?t=15905
          MXtras' Storage Cabinet Plans - http://reference.toolandfab.com/writ...nets/index.htm
            I don't know of any 3/32" tungsten that will melt at 125 amps (?)
              Very true.
              Scott
              American Made
                Does he have variable polarity "AC"? If so, maybe the reverse current cycle is turned up so high that he has it doing DC reverse current. That might melt a tungsten at 125A.
                  Answer: To much current for the size electrode used. JG
                  Long time Teacher - Processes
                  Owner - 2 LWS's
                  Hobart - Lincoln- Miller - ESAB(Linde)
                    Well, that's an answer, as you said... a wrong answer.
                    Unless the American Welding Society, Miller Welding, Lincoln Welding, and a host of welding textbook authors all got it wrong. As Rocky said, 125A AC will not melt 3/32" tungsten in the presence of sufficient shielding.
                    Hobart HH 125EZ
                      Yes I agree totally 125amps will not do it unless like they said" wrong polarity" or you also metioned HF start you need continuous HF to weld aluminum tig. Pure tungsten was alway's used for aluminum but times have changed. They have other's you can used as mentioned also zerconiated or thoriated.
                        OK lets start from the beginning here: I like 1/8 in tungsten for just about anything thicker than 1/8 on aluminum......Pure tungsten, set the machine on AC (If it is a SQ wave balance the wave depending on cast cleanliness) If it is kinda dirty set the wave depth a couple clicks toward cleaning cycle from Balanced.
                        use pure argon set flow to 10 CFH and I would use 4043 filler probably 3/32
                        Preheat with OA rosebud depending on how big a part it is...Cast aluminum will suck the heat away fast......I soot up the area with a rich flame and then set a neutral flame and heat till the black disappears...Your ready to weld....If you still have tungsten problems then I would suspect problems with the machine.....
                        Dynasty 350
                        Hobart Beta Mig 200
                        Twenty seven Hammers
                        Three Crow Bars
                        One English Springer Dog
                        A Big Rock
