cheers everybody, i have a question as to what type of stone doesn't get loaded up when you try to cut aluminum? or is there a stone you can put into a hand drill or dremel tool that you can "mill" aluminum? sincerely, snakesaver
stone to cut aluminum
If you need to remove a significant amount of material, a grinding burr would be advisable. Aluminum can be surface ground, usually with a relatively soft silicon carbide wheel. A sanding disk and a bit of lubricant would be better for hand use.--- RJL ----------------------------------------------
I've had pretty good luck with those cone shaped ones made from a wound strip of abrasive paper. They screw onto a long screw shaped arbor. 'seems like I used to get them from Eastwood. I hogged out some manifolds with them and mill cutters in a die grinder...but aluminum clogs everything eventually."Good Enough Never Is"
For die grinder (or dremel) use, I would second the use of a burr. There are burrs made specifically for soft metals. Single cut clogs up less than double cut (look like a milling cutter, because they basically are). The ones made for soft metals have deeper throats between the cutting edges and the edge geometry is different than those for steel. For light work, even a cheap "rotary rasp" from the box store will do the job ok. For surfacing, use wheels made for aluminum in a 4.5" grinder. They have a softer bond than wheels for steel that releases the grit as the wheel becomes loaded.I may not be good looking, but I make up for it with my dazzling lack of personality
