Looking for information on what type of aluminum to use to build a rock drill mast. I want too weld to pieces 0f 5" aluminum association C channel together with two pieces of extruded aluminum bars to form a box. A square tube will not work becaue I need the extensions of the C channel to slide the drill up and down the drill mast. The C channel will be welded together with the channels or extendion angles away from each other to form a square box with extensions on it.
What type of aluminum do you recommend I use 2024 or 6061 or other type of aluminum?
The aluminum mast will be 13 feet long. The drill and mounting bracket will weigh 420 pounds and travel via steel roller chain up and down the mast.
I plan on using aluminum association channel alloy 6061-T6:
5 inches wide with angles of 2.75 inches long, width of web 0.19 and width of angles 0.320.
Two of these would be welded together with extruded aluminum flat bar 4 inches wide and 3/8 inch thick.
Two of these flat bars, one welded flush with the out side of the two channel pieces and the other flat bar welded between the two channels about 1.5 inches in from the edge, for the steel roller chain to travel in.
I am wondering if the mast can be welded together without heat treating the aluminum after its welded together?
What do you think - would the mast be strong enough to hold together and not bend even if the mast is tiped to one side at a slight angle, say on a clock dial angles at a number 2 or 10, think it would hold together?
The mast would be mounted to a mini excavator stick where the bucket would mount, take the bucket off put mast on, two machines in one.
The drill is one of those hand held rock drills only weighs 66 pounds by itself but with the steel roller chain feed, hydraulic drive motor for the chain feed, mounting bracket of drill to mast and drill rod steel, it totals under 420 pounds with a safety factor included.
What ever input you can give me it will be greatly appreciated.
Mom & Pop businesses have to be creative to make a living, thats just the way it is.
I have a small dirt contracting business, right now really dead in the business field, have time to make this drill mast what I wanted to do for some time now.
So help me do it. Help me get-herrr-done.
