Hey everybody, long time no post.
I have a few projects I need to tackle (Namely an aluminum fuel tank for a FSAE race car, proprietary design so pictures will follow at a later date), and I need some help. I have done a ton of work with .125 and don't seem to have much of a problem, even with material slightly thinner, but .065 is new for me.
Using a Dynasty 200DX, 100% pure argon. At the moment, Im using 3/32 filler, and have been using 2% thoriated (I enjoy the radiation), no but seriously, I wasn't liking the 100% tungsten. Unfortunately, at the moment, It is the only size tungsten I have available, in a few days 1/16th tungsten will arrive.
Machine is set on AC, 75 amps, 40% on the balance, Pulse is on at 60hz, HF is set to 200hz.
Im sure these settings are way off, but I was messing around with it, and this is where I seemed to get the best results, but again, I didn't try every combination. I was wondering if you guys could point me in the right direction for welding "open" corner joints? I can't seem to get a really nice bead, its more like a mushy bead with out any nice definition like my "practice" beads had on flat plate. Any tips?
Also, I am having a **** of a time tacking and getting the beads started. When the beads are started, I can manage the puddle and keep it from dropping out, but I am having a heck of a time actually getting the two pieces joined initially, It seems like if I try and get heat in one piece then the other and back and fourth, neither puddle is molten and the filler ball-s up on me. If I try and hold heat on one side and add filler, I can get it to build up on top, but have a problem getting the added filler to join to the other piece!
Any advice? This is seriously difficult! Been working for about 4 hours with this material trying to get the machine dialed in and perfecting corner joints and, like I said, getting the beads started is a pain, but the good news is, when I get them running, they are strong and air tight.
Any tips from you guys would be great!
thanks
Jim
thanks
Jim
