Trouble with inside corner welds
  • Trouble with inside corner welds
    I have trouble achieving an even weld and getting the aluminum to flow into and around the corner for inside corner welds. I end up with an uneven weld with a larger weld in the corner as shown in the attached pictures. I need to heat up the corner for a long time to get it to flow. Any tips or tricks would be appreciated.
    Current: 160 amps
    Frequency: 250 Hz
    Tungsten: 3/32 Tri Mix
    Balance: 70%
    BC your inside corner welds always look so uniform. Anything that you can share on how to do this?
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    I like to start from the outside and weld to the corner from both sides rather than a continuous bead..
    and then hit it hard after Im done in the center of the corner...It doesn't offer
    any more strength, but I like the way it looks...(That's what happens to you when you are asked for COSMETIC welds) Setting your wave to penetration side helps keep everything tight also
    Dynasty 350
    Hobart Beta Mig 200
    Twenty seven Hammers
    Three Crow Bars
    One English Springer Dog
    A Big Rock
      Originally posted by B_C View Post
      I like to start from the outside and weld to the corner from both sides rather than a continuous bead.. and then hit it hard after I'm done in the center of the corner
      Thanks for your input. I will try that technique.
      I noticed that the second leg of the weld flowed better then the first, because the metal was pre heated. The pictures that I posted were my practice pieces. The actual part was a 1/8 x 1 x1 Angle welded into a 20" x 20" frame. I noticed that the welds on the actual part didn't flow as well as the sample piece. I believe that the longer pieces of angle acted as a heat sink that cooled down the weld. Would you preheat for this weldment?
      sigpic
      Miller Thunderbolt
      Lincoln LE 31 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Unless it's thin material I use Alumix gas on all aluminum. It's just so much nicer. And I kinda like EASY...Easy is good. You have helium,
        take advantage of it....I mix it with argon all the time to help wet out those hard spots... Sure you can pre-heat that thick stuff but unless it is really thick and big I use more helium...
        Dynasty 350
        Hobart Beta Mig 200
        Three Crow Bars
        A Big Rock
          I noticed that my Airgas LWS sells Alumix. Would you recommend using that as is or purchasing a cylinder of helium and mixing it with Argon?
          The web site said call for price. Any idea of the cost?
          sigpic
          Miller Thunderbolt
          Lincoln LE 31 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            As is...Depending on the mix...Most Alumix bottles have 75 argon 25 helium...You can get Alumix
            with 75 helium 25 argon which is pretty aggressive for thinner material..
            Dynasty 350
            Hobart Beta Mig 200
            Three Crow Bars
            A Big Rock
              Thanks for the help.
              sigpic
              Miller Thunderbolt
              Lincoln LE 31 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Happy Thanksgiving...
                Dynasty 350
                Hobart Beta Mig 200
                Three Crow Bars
                A Big Rock
